My pool is gorgeous thanks to TFP. The problem is my in-laws 18k Fiberglas with fresh sand filter but using pucks only. Here are the numbers using tf-100.
FC-3.5
CC-0
PH-2.5 (yellow only with k1000, digital meter reads 2.5)
TA-0 (I’m guessing, sample turns bright red after adding R-0007 & R-0008)
CH-175
Cya-over 100
Water is cloudy, but not green. No visible algae. Are these PH and TA tests correct? Would that cause cloudiness? How quickly should I add soda ash? I’m thinking I need to balance the water, get them off trichlor pucks, and lower Cya ASAP. Any suggestions are greatly appreciated.
FC-3.5
CC-0
CH-175
Cya-over 100
