Hey guys, me and my wife just purchased our first house back in October. We have been busy fixing up and changing things inside and now with spring here we are looking at the outdoors
I will post some pics later on today and get a full description of everything I am working with, sand filter model and what not
Basically we have an above ground pool 18x54, that has been neglected since August of 2020 at least, we began draining it, as it sits under 2 big trees and currently has about 5 inches of water in it, our plan is to get in and get dirty trying to clean up all the leaves and gunk, or at least as much as we can(hopefully this wasn't a mistake)
My first question is, after the cleaning and before I call around to get it filled is there anything I can do to start fixing this problem? As of right now the water is dark green with algea just free floating around, I know chemicals can get expensive and I figure it will be cheaper to treat the little bit of water that's in there then to treat it full, I could probably throw in a pair of 2500 gph submersible pumps, for water movement to mix anything that needs yes they are from an aquarium (is this even going to make a dent)
I'm completely new to pools and maintenance and I don't know what to do, any help is greatly appreciated
Thanks
Thanks
