- Apr 10, 2018
- 5,196
- Plaster
- CircuPool RJ-45
Due to my high levels of CYA, I need to maintain an FC level of 6-9 ppm (SWG pool). I have a 2-year old with somewhat sensitive skin. Will exposing her to the higher chlorine levels create any problems for her or others that use the pool? I know I have some challenges ahead based on my high levels of CYA and CH. I'm in the process of figuring out how to do a partial drain while complying with local waste water disposal regulations.
Here are my current test results:
FC 8
CC 0
pH 7.4
TA 80
CH 750
CYA 120
Salt 4000
Borates 40
Water looks good. I'm up to about 77 degrees with the solar cover.
Thanks in advance,
Mike.
FC 8
CC 0
pH 7.4
TA 80
CH 750
CYA 120
Salt 4000
Borates 40
Thanks in advance,
Mike.
