Did you take the t-15 cell to the pool store or did you take a water sample to the pool store?
*Add one drop of R-0718 and stir after each drop. This is the dark colored Silver Nitrate which changes the color of the water from yellow to brick red. It has taken exactly 19 drops each time on almost a dozen tests I've performed. I also had my wife read and perform the test herself which rendered the exact same results. On the 17th drop it flashes a little brick red then returns fully to yellow. On the 18th drop is flashes a little more brick red then returns fully to yellow. On the 19th drop the water turns fully brick red and stays as such.
I had the pool water tested by a second pool store today "Leslies" and their reading is really close to what my SWG is showing and the other pool store (2400ppm, 2600ppm, 2800ppm) respectfully. I cut my pump run time and added some fresh water since the first pool store tested at 2800ppm. So the lower readings today would be expected. I consider all three of these readings to be nearly identical and highly accurate.Take a water sample to 3 pool stores, they will be different, trusting a pool store just leads you in circles.
