I have had few issues with my pool since I found TFP years back. Until now. We went on vacation for 2 weeks, added additional liquid chlorine, and a few pucks in a floating dispenser, as my CYA was low enough. When we returned, there was a bit of algae on the floor and on the shady walls. SLAMmed, then OCLT. PH, TA, CH all unchanged. Chlorine level adjusted. Then, since reading good things, I decided to try adding Borax. Ran my numbers on PoolMath, said to add 7+ boxes. Hmmm, that sounds like a lot. Previously started with 2 boxes, didn’t do much, Borates to 5. So, then I added 4 boxes. Yikes! The pH is a brilliant bright magenta red. Significant increase in TA. What to do? Values below.
Pre vacation: FC 3(raised to 16 day we left), CC 0, pH 7.6, TA 80, CH 80, CYA 45, Borates 5, Temp 83°
Post vacation : FC 1, CC 0, pH 7.3, TA 80, CH 80, CYA 50, Borates 5, Temp 84°
SLAM: ( 3 days) FC 14, CC 0, pH 7.4, TA 80, CH 80 CYA 50, Borates 5 Temp 84°, passed OCLT
Today:added 4 boxes borax yesterday: FC 5, CC 0, pH off the charts!, TA 140, CH 80, CYA 50, Borates 25, Temp 84°
Thanks!
Thanks!
