- Mar 8, 2013
- 10
First off I just wanna say thank you to everyone on this forum your help is greatly appreciated.
Alright so yesterday 6/12 I started cleaning up the pool. It was pretty green, couldn't see a few inches below the water level. I'm around 60 gallons of 10% in so far, cya converted to ammonia over the winter/spring. Chlorine is starting to hold somewhat. Retested cya and the reading I got today is actually a lot lower than what I tested before I started slamming, I'm guessing the murky green water skewed the results. PH might have been affected too because of the cloudy greenish water. Before slamming I adjusted the pH and it read 7.4 now JTS reading 7.0, bold yellow but it turns to a reddish hue after 20 seconds and eventually turns a dark purple. What could be causing this?
Here are my numbers:
PH: 7.0 initally then turns reddish after 15-20 seconds until dark purple a little while later
FC: 7.5 at the moment, it was at 35 since I though my cya was a lot higher. I'll be keeping FC at 13 which is shock level
CC: 2
TA: 120
Cya: 30
What could be throwing off my ph test?
CC: 2
TA: 120
Cya: 30
