Hi
I've had this pool for 10 years. It has been easy maintenance except for when it rains hard. Even when it rains just for a few hours. After a we receive a decent amount of rain, the pool water immediately begins to turn green (see picture of pool after only 30 minutes following a 2 hour rain). If unattended it will turn into a swamp in just a few a days (see 2nd pic). I can prevent this and keep it clean and clear by immediately adding the typical chemicals, brushing and vacuuming. However, I seem to be the only one in the neighborhood having this extreme change when it rains. After ruling out equipment and chemicals (as the chemicals can be perfect when it begins to rain and it still turns green in just a few hours). I think it is caused by the muddy rainwater run-off from the grass which flows over the concrete directly into the pool. We have french drains but they may not be enough. However, I'd like to know if anyone else has this issue and what they think the root cause might be? Pic 1 = 30 min after hard rain (deep end turning green, spa still clear but will turn green if untreated asap) | Pic 2 = 2 days after hard rain if unattended | Pic 3 = normal clear water
