Hi,
I'm not sure what material this pool is made of and how to patch this.
Do I need to hire a professional?
Picture attached. I could also have a 15-second video up soon (on yt as unlisted) - let me know.
Thank you!
Looks like plaster over gunite. I see a crack running to the upper left. Do how much of the plaster is delaminating? A patch will not hold if the areas around are coming loose. Really looks like you need a replaster job.
There are pool plaster repair materials. None will look pretty and match the colors.
This is the pool floor.
I think it's also plaster. I also see small crack now that you mention it.
I don't know the age of the pool, we bought this house 2 years ago.
Make easy repairs to your pool using this 3 lb. White Pool Plaster Repair Kit. The plaster can cure in as little as three hours. Use this to fix small cracks.
You really need to drain the pool and properly prepare the surface to have it stick. I have tried to do underwater repairs of grout and it is very difficult. Best to put a bonding coat on the gunite then plaster patch.
At E-Z Patch, a swimming pool & tile repair supplies company in Phoenix Area, we have always strived to provide repair and construction materials that last longer, look better and are easier for you, our customers, to work with
