Need opinions on what to do please
BadDogPSD
112
Reno, NV
The biggest differences between pucks and liquid chlorine is that liquid chlorine will require almost daily maintenance, but it won't add stabilizer so you won't have to deal with draining & refilling as a means to control the CYA levels.
My daily pool maintenance is 5-10 minutes. Check levels (Free Chlorine (FC), Combined Clorine (CC), and PH, add liquid chlorine and/or muriatic acid as recommended by Poolmath and enjoy the evening.
About once a month I'll check the rest Calcium Hardness (CH), Total Alkalinity (TA), and Stabilizer (CYA).
setsailsoon
3,475
Stuart/FL
Jca,
Not sure what the soils and water table are like in your area. In many locations if you drain and refill the pool you risk damage to the structure because it tends to want to float. In those cases or if your not sure, it's best to use the exchange method. Draining - Further Reading | Trouble Free Pool. Please ask any questions you have before you start.
CYA doesn't change very quickly but since you're new to this test may be good to test again. Remember outdoor only, back to the sun, and don't stare at the dot. Look away and then down at the dot. It's the most difficult test to do but your results are still more accurate than the pool store test.
I hope this helps.
Chris
setsailsoon
3,475
Stuart/FL
Based on the results you may need to SLAM but depends on the results. If you don't have any time to do more today it would be helpful to run an OCLT tonight if you can.
Chasarms
347
Dardenne Prairie, MO
Unfortunately, if the CYA levels given to you by the pool store are accurate, draining only 1/3 of the water isn’t going to get you there. If accurate, you should expect to still get results around 100-110. 40-60 is the target.
jcaj558
81
New Lenox, IL
So from what I’ve read it said to only drain like 18 inches or so at a time so the liner doesn’t shift.
setsailsoon
3,475
Stuart/FL
Slam? OLCT?
Before you do anything else please perform your CYA test again. If the result is over 100, dilute the sample with 50% tap water and test again then multiply the result by 2. The limit of the undiluted test is 100. We need to see how much CYA you actually have to know how much water must be drained. We do not place any confidence in the pool store test. Please post the diluted CYA test result and we'll go from there. After you get your CYA in range we'll see if you need to SLAM and/or make other adjustments.
Chris
OCLT Overnight Chlorine Loss Test
setsailsoon
3,475
Stuart/FL
J,
The Pool Frog system adds minerals. TFP does not use any methods like this since they can have very undesirable results including stains. Do you have any existing stains? I would use this time to get the minerals out with a complete water exchange. I'm going to ask a couple of people more familiar with minerals than me to comment. @mknauss @ajw22 can you please comment?
While waiting for their comment can you please post a current CYA result and then start another drain cycle.
Thanks.
Chris
jcaj558
81
New Lenox, IL
J,
Thanks.
Chris
I don’t have any stains. Really to my untrained eye the pool and water look really good. I won’t be able to post the numbers until this evening as I’m at work.
Reactions: setsailsoon
