My Pentair Dynamo 1.5HP 115V is leaking from the housing body. It's 10-11 years, so no sense replacing the housing. I run my pump 24/7, trust me it has to be. Also, I do like the stronger water flow, because I think it helps keep the wedding cake steps clean underneath, by moving water through the various holes I've drilled. Funny, when we installed the heater a couple years ago, the larger return line made a big difference in water flow, which was nice.
Anyway, I have 115V, twist lock outlet and am looking for a fairly easy swap. I have enough projects right now. My pool is relatively small and simply to operate, so I don't think any smart function would be an advantage, unless you think I'll be changing speeds more than once a day. If I matters, I believe 16GPM would turn my pool every 8 hours, but I'm not obsessed with turnover. I just know if the flow stops, I get pollen and other debris and it's not worth having to deal with that. Having never had a variable, I'm not sure when/why I would change speeds. So feel free to educate on that as well. I run my house HVAC with my phone and that's very handy.
Looking for specific model recommendations if anyone has them. Or, do I just replace the Dynamo with another single speed Dynamo?
Thanks
Thanks
