- Jun 26, 2011
- 17
10 x 40 SGW, plain rectangular, vinyl liner pool, 13 years old. Existing cover is LoopLoc. Cover is on its last winter, seam joints are separating because the cords used to sew panels together are disintegrating. Panels themselves are in pretty good condition. Did not use UV resistant material for cords?
I have found a local irrigation/pool supply company that is acceptable to Merlin or LoopLoc. But are there respectable on line sources for pool covers?
Also: Present cover is mesh letting water drain into pool. Several times during the winter the pool fills above the top of the liner. Is this a problem? I lower the water level using a small submerged pump. Others have this problem?
Comments welcome and appreciated.
Stephen
Stephen
