I have a pool/spa combo
Need my spa jets actuator connected to the aqualink rs8.
The spa jet actuator sends water to the jets or just thru the returns.
Currently using the intake, return and solar jva’s. I tried the cleaner jva which worked perfect except when the system is in spa mode
I get the warning not able in spa mode.
I was thinking of a wireless switch i could put at the spa somewhere and tap into the jets actuator and then the switch would tell the actuator to go in vice versa direction.
Not sure what i would need?
I could run a wire cable to the spa also.
Any help would be appreciated to get me started on this project. Ive seen some other post of possibilities but I'm confused as to the correct wires hooked up.
Thank you
Bill
Thank you
Bill
