- May 17, 2021
- 7
- Vinyl
- Intex Krystal Clear
Hi all, I have had intex pools for years. I just purchased a new 32x16x53 pool. While setting up, I noticed that my old pool outlet fittings won’t work with this pool. I used to have a 24x52 round pool. In 2013 I bought the sand filter//saltwater pump. It came with all the necessary parts and they fit. My new pool has 2 outlet places that are tiny. I want to use my old fittings that aren’t blocked by a stupid plastic grid. I use my vacuum attached directly to the outlet so that any leaves etc can go into the filter basket on that pump, like it should be used for. The new holes are too small for my old open fittings. I decided to try using the adapters so that I could use the screw on hoses, but they flip around and I know have a small leak in one of the black tubes on one outlet. Im
Not even going to go into what a pain it is to vacuum the pool. I’m hoping someone can offer some advise as to how to modify the outlets to fit the two older threaded fittings I have. I still have both plungers and fittings from my old pool and would like to use those on the outlets. Pictures are attached of what I have and what I want to use. First I’d what I have, second is what I want to use. I guess I need to cut the liner abs not sure how to do that because the reinforced area around to outlets is much smaller than the inlet that fits these parts. Any suggestions as how I should modify the set up and/or cut the liner? Should I cut both outlets? One of them is already leaking slightly from a small tear from hanging instead of being supported like the other fittings.
