Hi all - I have what I suspect is like a pin drop hole in my flexible hose. Every time I dry it, it gets a little wet again in this one spot. Any idea on what I can use to fill the hole? Maybe silicon? Maybe krazy glue? I don't know. It's like the 10th ridge from the top of the hose return back into the pool. It's not as simple as get a new hose as you can see from the 2nd pic its connected to my SWG that I had someone hook up.
Thank you
Thank you
