The skimmer works fine. But the vacuum accessories are sun bleached and brittle. So the cover is broken and there is suppose to be a seal. Image 1 is the skim filter in use. Then I pull the skimmer basket out and insert Image 2 filter vacuum accessory the the top cover goes on where I connect the vacuum hose. This allows me to trap large debris from the pool bottom in the skimmer instead of it all flowing into the sand filter. I have in years past used / put a sock filter into the inner skimmer canister. I have looked at many vacuum filter caps but they dont specify the diameter, my skimmer is about 7 3/8" inside diameter.... hayward / bestpool has them but no specs I can find of inside diameter.... If anyone can find a new skimmer vacumm top lid would be fantastic Thanx in advance Todd Littleton CO
