So the frustration level is getting a bit high right now. I'm the typical DIY type and have experience in many areas. I've recently gained a lot of experience with our spa. It's a 2013 Hot Spot Relay. Recently pump 1 began to hum instead of turn on when I hit the jets button the first time, eventually popping the circuit breaker. This is the pump one low setting. If I hit the jets button to go into the next three settings (pump one high, all pumps, pump 2 high, etc...) they all worked just fine. Initial findings on the internet stated that the solenoid on the pump may be bad. So I replaced it. While in the spa I checked it's rotation of the pump and impeller to make sure they were good, they were. When I started it back up, same thing happened but the circuit breaker did not pop.
So, back to research. It was mentioned that the control pad mounted on the top of the spa could be bad. This was not a surprise as some of the digital display had gone out so I was going to replace it anyway. I bought a new one and installed it, didn't change anything.
So I went back to the pump itself and just decided to buy a new one. That didn't work either. So now I have a spare pump... lol.
I found that the fuses on the control board could be bad. Replaced them, no change. Then I found the control board itself could be bad (relay or other component on it). Bought a new one. It arrived DOA. Second one came in and I installed it. Now when I press the jets button once it makes the normal click sound and it does not hum. Instead it does nothing and the display eventually reads ========== . It also does this on every jet mode, just a click (relay) and nothing and the display goes ========. So I looked at the manual trouble shooting guide and it tells me that it means the pressure switch is bad. I found some tricks on the internet to make sure it's not just an air pocket. They didn't work. So I got a new pressure switch. It is now installed and - nothing changed. Still getting the =========== on the display.
So I am now in ??? mode. I've confirmed several times that I am getting the proper voltage to the control board. It's all properly grounded. Any suggestions??? I had to replace the heater a few years ago. Could it be the heater again? I've replaced everything but the #2 pump at this point. I'm completely baffled. $825 spent so far, which isn't horrible but I just don't want to throw more money at it.
Any help would be greatly appreciated
