so after about two weeks of trying to balance my water and get it clear I could not get the FC to hold. I have a SWG. Testing with the Taylor K 2006 test kit
Finally decided there’s probably invisible algae or something in there that was not getting out. Drained the pool quarter of the way, Scrubbed the walls, backwashed waste, filled it so the vacuum could go on vacuumed up whatever was in there on the bottom, rinsed and backwashed filter, refilled the skimmer level. pool still looks a little cloudy filter has been running for five hours.
I don’t even know if we did that right but it’s the only thing I could try to do to make it clear. I looked up what to do and this is what I found I don’t know if I followed it correctly.
can I test the water now or do I have to wait longer? and what do I look at to balance first?
thank you
So update decided to test after 4 hours
FC 0
Cya 45
Alk 110
CH 220
PH 7.0
help please
thank you
FC 0
Cya 45
Alk 110
CH 220
PH 7.0
help please
