Need Help-Getting No Water Flow Timeout FlowSensorhaywardomnilogic
rosprayb
1
Alabama
My main pool pump will only run for a few minutes before it shuts off due to no water flow error from Omnilogic.
The pump is primed and water is in it.
I backwashed sand filter and clean T Cell.
It will not stay on when freeze protect kicks in on low temperatures also.
I am watching pump and it is running and primed but still shuts off with water moving. No air bubbles.
Pool is full of water.
Spa pump, bubbler pump, and overflow spa water spill works fine. Only main pool pump shuts off.
No leaks at pump.
What can be problem? Sub freezing temperatures are coming in 3 days.
Welcome o TFP.
Show us pics of your equipment pad.
Where is your flow switch located?
Check the flow switch for proper operation.
Maybe replace the flow switch.
