Started last night at 11 PM. I reduced ph and increased cya before I started the slam.If you are sure on your CYA test, no need to go above 12 ppm FC. It could harm your liner.
How long have you had FC at SLAM level?
Yeah I'm heading home now, I'll get you all the numbers.Could you test your CYA one more time? I have a feeling it may be a touch over 30, which would mean SLAM at 40.
Cya still at 30, fc 19, cc .5.Could you test your CYA one more time? I have a feeling it may be a touch over 30, which would mean SLAM at 40.
I did it in my garage, it is very well lit. I always test with my back to the lights. I was targeting 20 fc just in case, I read on another post that over shooting within reason is better than dropping below slam level. I'm heading out now to give it another vac then brush. I can probably get another test in tonight. I'll hit it again in the morning then the wife has been trained to test and adjust tomorrow while I'm at work. I'll be home at lunch to check on her work! I know it's not the tfp way but what do you guys think about some flock or clarifier?CYA needs to be tested in bright sunshine.
CYA - Cyanuric Acid Test - Trouble Free Pool
Cyanuric Acid (CYA) is the chemical name for what is commonly referred to as Stabilizer … Read more…www.troublefreepool.com
Incorrect. It is best to not appreciably overshoot your SLAM level FC. You risk vinyl liner damage. The excess FC will burn off quickly due to UV. You are killing algae as long as your FC is above the minimum based on your CYA.I read on another post that over shooting within reason is better than dropping below slam level.
I had my cleaner (cheapo intex) in for the last 4 hours and the pic shows all I got. Vacuum isn't getting much either, just hair, sand and some saw dust from the deck build. Do you think the cleaner is helping at all? I feel likeCYA needs to be tested in bright sunshine.
Noted. So stick to the 12 as recommended by the chart? I imagine it will be easier to return to swim able levels as well. Also, I ran my cleaner (cheapo intex) for the last 4 hours and all I'm picking up is hair, sand and sawdust from the deck build. Vacuuming is only picking up the same stuff. So I even bother with either?Incorrect. It is best to not appreciably overshoot your SLAM level FC. You risk vinyl liner damage. The excess FC will burn off quickly due to UV. You are killing algae as long as your FC is above the minimum based on your CYA.
Any thoughts on the cleaner, I feel like I get better circulation with it?? Updated pic too, seems to be turning to a greater color but still cloudy as heck. Clarifier or floc? Seems like the filter, vac and cleaner cant get the fine stuff and just shoots it back into the pool.SLAM level FC is safe to swim in. As long as you can see the bottom of the pool.
I brushed it 3 times today and vac'd it twice. Doesn't seem to be any visible algae on the walls though. They dont feel slimy or anything. Just cloudy green water......weird. I trust you guys and will heed your advice. I sincerely apreciate everyone's help greatly!Clarifier and especially floc are not recommended by TFP.
Anything you can do to keep the water mixed and any algae on the walls disturbed will help.
That is odd with how your water looks. Again, I am concerned this is iron, or copper.They dont feel slimy or anything.
Thank ya buddy. I back washed first thing this morning and the pump is still at the optimal psi, kind of concerns me. I keep the pool very clean so no debris other than small amount of hair, sand and sawdust in my vac or cleaner today. I do apreciate the support. Feel free to share any other thoughts.We are all rooting for you to wake up to a blue (but likely still cloudy) pool. How is your filter doing? Do you need to backwash at all?
How can I test for that? I have a tf100 kit. I'd be happy to check it. I can run to the pool store and have them test it but we all know what a great job they do.That is odd with how your water looks. Again, I am concerned this is iron, or copper.
