- Jul 4, 2012
- 749
- Vinyl
- CircuPool RJ-60 Plus
Guy, I don't think it is a flame roll out switch. The second picture I posted is just the supply pipe from the first picture coming into and connecting to the unit. In other words, as you are looking at the first picture I posted, if you were to step around to the right (where you would be facing the "photographer") that is the front of the unit. I removed that panel and now you are seeing that same supply pipe from pic 1, coming in from the left side and into the unit.
Thanks Jason, yeah, went out and took another look and it does indeed appear to be a pipe size adapter. That old sticker on the pipe that you can see actually says 1/2" by 6" nipple. Is there really no way to remove this without cutting?
