I opened the pool on saturday and the water was crystal clear. But there's something that looks like sand all over the bottom of the pool. No idea where sand would have come from, but similar beige color. My initial readings are below, and I have a ~20,000 gallon poured concrete pool with an Anthony Apollo 52 sq ft DE filter and a 1 HP pump.
FC 0
CC 0
TC 0
CH 200
TA 60
CYA 0
I got to work raising my CYA (got a little carried away and have it up to 50) and brushing and vacuuming the pool. By the time I finished vacuuming the pool was very cloudy and I haven't been able to clear the cloudiness and the sand keeps coming back on the bottom of the pool. Yesterday and again today I vacuumed the pool with the valve set to backwash thinking that will evacuate the sand. I've tried to SLAM but have had issues getting my FC levels up. I used the pool math and by adding 3 gallons of chlorine (I buy 12.5% liquid chlorine from a local pool supply store in 5 gallon containers) I should get up to a FC of 20. I just put in 3 gallons and took a measurement 20 minutes later and only read 3 FC and 1 CC. Since Saturday I've put in 20 gallons of the 12.5% liquid chlorine and I can't get my FC up high enough to SLAM. I don't believe that there's an issue with the quality of my chlorine as I was able to raise the FC level in the adjoined hot tub. The water is still cloudy but starting to clear a bit.
I've also had issues with the filter. It keeps getting clogged the pressure of the water coming out is relatively low and it's running at about 20 psi. If I backwash or open the filter or hose off all of the fins it gets better and drops to about 10 psi, but within a few hours creeps back up and the flow slows down.
I'm not sure what to do from here. I thought 10 gallons of liquid chlorine would have been enough to get through the SLAM process. Is my frame of reference way off? How much chlorine should I have on hand to get through the SLAM process? Is there something else I should be doing besides adding liquid chlorine
FC 0
CC 0
TC 0
CH 200
TA 60
CYA 0
