Need creative ideas for underground plumbing repair
desoto
Active member
Feb 26, 2010
32
SoCal
This strange plumbing is on the dedicated vacuum suction line. It sits under a concrete wall (!?!) and the adjacent pipe is tight next to it. The pipes were and are in hard clay (not sand). Due to a leak at this spot (surprise!), I need to replace this section of elbows. Any suggestions on how best to do this?
JamesW
23,391
It looks like they missed a glue joint on the front top 90 because there is no blue glue showing like on the other 90s.
desoto
Active member
Feb 26, 2010
32
SoCal
It looks that way, but no, it's glued just fine. It's the far bottom joint that is the problem.
Jimrahbe
20,900
Bedford, TX
D,
I'd do this... Cut out the bad 90, and add a new 90 pointed straight out, This would allow you to bring the problem out where you can get to it..
Reactions: 1Sammy
desoto
Active member
Feb 26, 2010
32
SoCal
D,
Thank you, Jim. That looks like a good solution. I'm a little worried about how hard it might be to glue the last piece in. Maybe if I cut the longest long enough (3 feet?), there'd be enough flex? Will give it a go. Thanks again!
Reactions: Jimrahbe
Technigogo
97
Austin, Texas
I would get rid of that unnecessary bend up and back down while you are at it. Cut back on the pipe by the wall, cut back on the pipe in the front of the picture and then reattach with elbow, couplers and pipe. I can't tell if that is a 90 degree angle in the picture though. You could also consider flex pipe.
