Hi!
Just started this system, and it seems that something is missing in the settings or implementation. If I set the timer on the pump to 5 it will run from that moment, 5 hours onwards and then sleep until roughly the same time next day. Our pump should run min 5 hours and the salt water system for about 4 hours according to specs. So about 30 min after pump started I start the salt system and set it to 4 hours. Works fine... BUT
What if I want to run the pump manually maybe later in the night for cleaning or vaccum or whatever? Can I just switch to FP and let it run, and then switch back to 5 and it will remember the old cycle? I can't get this to work, because when I switch back to 5 it will keep running, even though it is "off" the 5 hour interval. it is like it restarts the 5 hour cycle using that exact time as start time, and forgot the old start time. And this means the salt system and pump are not in sync anymore. The heater is fine, it just stops when water flow stops...
What if I turn off the power to the system, will it remember everything when power comes back on?
Is there any way to set this stuff up using a normal timer with hours and minutes? Any add-on or gadget I can get?
I want to run the pump during the day because of the heater is more effective during the warm hours here in Sweden, say from 9 AM to 7 PM, then I want the system to be idle, maybe with some manual vaccum or backwashing later in the evening when no one is swimming. Can this be done with the current setup?
I am very pleased with the filter and pump as it is now, it is easy to use, very quiet and no leaks or anything. Works like a charm, except for the strange timer system.
Thanks/H
Thanks/H
