@HermanTX @Mdragger88
Update: All planned treatment completed in baby steps (i.e. 50% to 60% of required levels of CYA & Salt). Since this was my first ever attempt, wanted to be extra careful. Performed a complete test today after 60 hours since the start of the treatment.
Treatment & Test Results:
On 9/27/22: FC = 3; CC = 0.5; pH = 8.0; TA = 50; CH = 475; CYA = Not Tested; Salt = 1600
On 9/29/22 (just before the start of the treatment): FC = 4 ppm; CC = 0 ppm; Salt = 1600 ppm; CYA was not tested due to R-0013 unavailability.
Added 2 lbs of dry stabilizer; 160 lbs of Salt; 0.5 gallons of 7.4% bleach. SWG was off & Pump/Filter was set to run 24 hours.
On 9/30/22 (after 24 hours of pump runtime): FC = 3 ppm; CC = 0; Salt = 2600 ppm; CYA was not tested as it wasn't 48 hours yet.
Turned on SWG and set pump/filter to normal schedule i.e. 10 hours over night.
On 10/1/22 (after 60 hours after treatment): FC = 4 ppm; CC = 0; pH = 7.8; CYA = 50; Salt = 2600 ppm; TA = Not tested as PoolMath indicated no impact; CH = Not tested as PoolMath indicated no impact.
Next Steps:
* Add 80 lbs of Salt which per PoolMath adds 562 ppm taking the Pool's Salt to 3100ish ppm.
* Add 2.5 lbs of Dry Stabilizer which per PoolMath adds 18 ppm of CYA resulting finally in 60~=70 ppm. Also lowers pH by 0.3 resulting finally in 7.5.
* Test TA to confirm whether it remains at 50. If yes, add 5 lbs of Baking Soda (no impact to pH under 6 lbs of Baking Soda w.r.t my Pool per PoolMath) adds 21 ppm resulting finally in 70 ppm.
* Test FC w.r.t CYA and figure out next steps to update SWG output which is set to 50% as of now.
Question:
1. Any specific instructions on how to add Baking Soda? Can it be added along with CYA & Salt or needs an ordered sequence?
2. Curious to know whether it is a must to run pump for 24 hours continuously or it is OK to add CYA using my normal run schedule i.e. 10 hours runtime every night. Meaning, the CYA will get mixed into the pool gradually over two nights instead of next 24 hours. I'm in no rush but at the same time I don't want to sabotage the treatment. Please let me know your thoughts.
