I am burying an aquasport 52 28" inches in the ground and I have two questions...
1. Since it is too cold to put the liner in, can I go ahead and backfill (only the 28") and wait until next spring to drop in the liner?
Two notes to consider for question 1:
A. The pool is buried in hard clay soil so I do not fear any "cave-ins" from the pool being open without a liner, but I would like to hear advice from the experts.
B. Since it is only 28" in the ground (and only 19" in the ground on 1 side - because of the slope of the yard) it will have 24" above ground on one side and 33" exposed on the other side....supporting my reasoning why I don't think it will collapse.
2. When backfilling up against the aluminum wall, is there any fear of corrosion from contact with the soil and if so, what product would you use to coat that outside to prevent corrosion? I read on here somewhere there was a product to spray on that "rubberized" the outside of the walls...but I can't remember the name...I wanna say something like..Blue Max or something similar...
Any help is appreciated.
Thanks
Thanks
