Need advice on base for hot tub on existing concrete
Apr 21, 2012
18
So we just got our new concrete put in when the pool was put in, where I want to place the hot tub (see pic) the ground slopes away from the house and towards the house to meet at the deco drain. I want to place the tub almost flush with the window as it's exactly 7ft wide. Trying to figure the best way to make this level for the tub..
Suggestions??
I've seen some folks frame up and pour a level concrete pad on top of the patio. Or Our patio was also very sloped and I built a composite deck on it using pressure treated joists 12" oc starting at 1" thick and ending at 5-ish.
So we just got our new concrete put in when the pool was put in, where I want to place the hot tub (see pic) the ground slopes away from the house and towards the house to meet at the deco drain concrete takeoff. I want to place the tub almost flush with the window as it's exactly 7ft wide. Trying to figure the best way to make this level for the tub..
Suggestions??
Hi, I am getting estimates for my new patio for my 3 seater hot tub. It's going to be about 10x8 feet. The hot tub will measure around 7x5.5 so I think that it big enough. Besides the patio being level and at least 4 inches thick or more is there anything else I need to request? I was concerned about water drainage so he gave me two options. Here is his quote if I pay cash.
$1095 Concrete pad only
$1215 including Cut lines
$1450 with 2 drain and pipes
