Hi Friends,
I'm using an old 1HP SF1.65 3450RPM single speed star-rite pump (AO Smith motor SQ1102) for my pool and spa. The motor consumes 9.6A max at 230V. The pump runs great but it is noisy and consumes 1.8KW read from the electric meter. I would like to change to the latest VSP with as I heard it runs much more quieter with higher efficiency.
There are three options here;
1) Pentair Intelliflo 011018. This is a very popular and reliable pump and price is good now. However this is a 3HP pump. Probably I need to upgrade my wire gauge. In addition, I'm not sure if using a 3HP pump on my old system plumbing would cause any issue or not.
2) Pentair Intelliflo i1 011059. This pump is more expensive, but it is advertised make retrofit easier since it consumes less than 7A current. It looks I do not need to upgrade any electrical wire or plumbing. I don't see any HP information of 011059, but only GPM curves. I've no idea if the GPM is large enough as a replacement of my current pump.
3) there's also a 011060, which is slightly stronger than 059, consumes 11.8A max current.
Would you recommend to upgrade to 011059 or 011018 with larger wire gauges?
