So I've never posted to TFP before, but I wouldn't say I'm new because I've been a reader here for several years. I switched from pool store debauchery to liquid chlorine and the SLAM process so I've been a follower and a fan for a while. However I only just got my first Taylor K-2006 test kit this week.
I've SLAM'd before (with guess strips unfortunately) and usually I don't have issues.
This time seems like it's really taking a while, but that could be just in my head. When I opened my pool a couple of weeks ago it was green. About as green as it gets. Normally I SLAM, the algae dies and falls to the bottom while the water clarity is pretty fair, I vacuum, keep up the process and wind up with pretty clear water.
This time I think I'm on the right track but I'm just getting a bit worried I guess. I SLAMMED the green away to blue, but I've had foggy water for about 4 or 5 days now. I have been backwashing, and I've attempted to vacuum even though I haven't been able to see the bottom. We've brushed the walls, pool steps, etc. (Note that I've only just gotten a Taylor Test kit yesterday.)
I've only seen a slight improvement in water clarity, and even then the pessimist in me wants to think that's wishful thinking. The pool is blue, free of large algae blooms (tiny guys here and there), but it is persistent on being cloudy.
When I opened, my readings were basically zero. I adjusted (before I had my kit mind you) and got
FC: >10
PH: 7.5
TA: 50
TH: 0
CYA: 40
I've continued to SLAM, I took a reading for chlorine an hour ago and got:
FC: 8
CC: 0.4...?
(New to the K2006)
Should I stay the course? I do know from my reading here that testing PH right now is unreliable but it WAS in acceptable range. That being said, can I test anything else with my kit while SLAMming? CYA? TA? Would it even be necessary? Also I'm certain I did the CC test correctly but got a 0.4? Does this sound correct?
The only other details I can think to offer is that my sand filter should be okay because the filter itself and sand were replaced new last year. Any reason to think it needs to be opened and cleaned?
If anyone needs any other details I can offer them best I can.
30ft above ground vinyl pool.
21240gal
Hayward 1.5hp pump.
150lb sand filter
FC: >10
PH: 7.5
TA: 50
TH: 0
CYA: 40
FC: 8
CC: 0.4...?
(New to the K2006)
21240gal
Hayward 1.5hp pump.
150lb sand filter
