Sorry you didn't get a response last night I thought someone else might pick up where I left off.
I would suggest the following - have you played with the Pool Calculator? You should play with it a little, get to know how it works because you'll need to use it daily to calculate how much chems to add.
Take out the N2 cartridge and any trichlor tabs. Dispose.
1. Add enough bleach to reach shock level. Leave the pump running until the water is crystal clear.
(You can buy Clorox, the large 182 oz jugs, you'll need at least 4 to start (8 small) but will probably need a bit more so it's okay to stock up a bit, say 8 large or 12-14 small.... Wal-marts and Target's store brand bleach is cheaper, the jug size is slightly smaller but that's okay. If you can get 10-12.5% liquid chlorine from a pool store for around $3.00 a gallon, that's your best buy, and it will mean less jugs to carrry. Aldi bleach is good too. Avoid Biglots and Dollar Store bleaches.)
2. Today and/or tonight, add enough bleach to raise it to shock level. I used the Pool Calc and got 591 oz of 6% bleach. Pour it in, jug by jug, slowly to prevent splashing, over the return flow. Then, after sunset, waiting
30 minutes after the bleach addition, perform an overnight FC test. Test the FC/CC, and record the result. In the morning, before the sun hits the pool, test the FC and CC again.
You are done shocking when you lose less than 1ppm of FC overnight, and your CC is .5 or less, and your water is clear. If these three things haven't happened by tomorrow morning, then you need to repeat the shock process/overnight test, until it does.
REgarding the TA and PH. Shock levels and anything above 10 FC will make the PH read a false-high. It is best to test and adjust PH when the FC level is below 10. So it will be too difficult to lower your TA while shocking. So tackle the chlorine issue first. Once that's done you can begin to lower the TA...
but - you didn't confirm if you repeated the TA test and if the result was the same. Did you try wiping the tip, did the results change?
So confirm that, and then lets tackle shocking. If during the process you notice high PH results, we need for the FC to drop below 10 before you can adjust the PH with acid. Do not try to adjust the PH if the FC is above 10.
Okay, I know it's alot but I hope this makes sense. Ask away if you are confused about anything.
