My To do list for 2021 swim season.
damon5683
30
Annapolis,MD
CircuPool Universal40
Hello Everyone, Thanks for your help in 2020 getting my pool going.
This year I want to add a propane heater, Variable speed pump and CircuPool RJ60-SWG to my setup.
I thinking about going to Leslies for the pool equipment and install because it seems so many people are not dependable in this area.
I do have a cousin who is a plumber and I know an electrician that could help on install if tried to do it my self.
I also have a small leak somewhere in the plumbing I believe.
Help me figure out what should I tackle first.
It sounds like you are replumbing everything around your filter. Post pics of your equipment pad so we see what you are working with.
Is your Superpump 120V or 240V?
What VS pump are you looking at?
My super pump is 120v
Here is my pad.
Where are you going to locate the heater? You can’t put a gas heater under a deck like it looks you have.
You want to keep your equipment there or move it?
Reactions: damon5683
get hi temp unions and jandy never lube valves :)
OK, I could put the heater in different location. I could move the equipment around depending on the the cost. I may have to just do a new pump and SWG. I would have to find another way to raise the pool temperature.
