I'm sure that there are resources on here that can tell you what size horsepower pump and filter is recommended for the gallon size of your pool. I have browsed them before in the past, just don't know where to find them at the moment I'll search in a little while. I would recommend with a pool generally of your size you want a pump motor that's at least one horsepower or stronger. There are ratings of water gallon turnover rate with different size canisters sand filters cartridge filters Etc for how many gallons you have in your pool. My one and a half horsepower motor should turn over my pool completely in 8 to 10 hours for my 7200 gal. Pool.
It looks to me right now that you are at cloudy blue. Stick with what you have for right now as far as your primary filtration. The Duda diesel bags at 5 Micron will take it from here. It will get you clear within three or four days.
I am going to recommend that you record your clean starting operating pressure which should generally be between 9 psi and 12 psi, check your bags, your skimmer sock or hair net if it is loading up with gunk, and your PSI every hour, and DO NOT ALLOW THE POSITIVE BACK PRESSURE OF THE BAGS, or THE NEGATIVE PRESSURE VACUUM OF YOUR SKIMMER SOCKS OR HAIRNETS, RAISE YOUR PSI ABOVE 18 TO 20 PSI. Or 10 psi above clean starting pressure. It will put a mild strain on the pump motor and skimmer basket with prolonged use over long periods of time. The more clogged that your primary or secondary filters get the better they are filtrating effectively, but this also obstructs water flow and creates pressure on your primary filter and pump. Over time of rinsing your secondary filters like your bag and your skimmer sock, or hair net, your water will get clearer, and the skimmer sock and bag will load up less, appear cleaner, thus creating less back pressure. Even though my water is clear right now it is not crystal sparkling clear. I have been running my Duda bag and skimmer sock since yesterday at 4:30 pm which is about 18 hrs. I am only at 12 to 14 psi.
The reason why your pool is at the cloudy blue stage right now, that's because the algae which is now dead, has turned white, and has to be filtered out by the five Micron bag. You will see it as brown residue on your skimmer sock and Diesel bag when it gets filtered out properly.
