My pool system is not pulling water
EveF
1
Milford MA
Hello, i'm new here hoping someone can help me with a pool matter. The pump turns on but not circulates water, I can see bubbles coming from the return line. I have tried to prime it, remove and clean the baskets, so far nothing work. motor just been replaced. I read you
Eve,
Show us some pics of your equipment pad. This really will help us to help you..
Do you have an inground pool or an above ground pool?
Assuming an inground pool, the pump works off of suction, so the first thing to check is that the gasket under the pump basket lid looks ok and has been coated with pool lube.
Also, make sure any valves that control the flow of water are open.
The more you can show us or tell us the better answers you will get.
