I had started writing this post before I realized my numbers were off. I've gone back and corrected it, but I may have missed something.
I tried using the pool calculator, and am going to post what I did and what it told me (not sure I did it right, being the first time and all).
At the bottom, I put in 14 W x 28 L x 7 D (our average depth), which gave 20,500 gallons.
I put the primary source of chlorine as bleach. I put the pool surface as plaster. (Don't know temperature, left that at 84 degrees.)
Here are the "Now" and "Target" numbers I put in, and the results the calculator gave me:
FC - Now: 0 Target: 4 - Results: Add 102 oz. 10% bleach. (Mine says it's 10% and is in 1 gallon containers, so a little less than a gallon?)
pH - Now: 8.0 Target: 7.5 - Results: Given TA of 70 and Borate of 0, add 42 oz. of 15.7% muriatic acid. (Mine says it 14.5% and is in 1 gallon containers, so how do I recalculate that? Math is not my forte. Ask me anything about ancient Rome or Greece, and I can tell you, but math is not a strong suit. Help? Please?)
TA - Now: 70 Target: 100 - Results: Add 144 oz. by weight or 115 oz. by volume baking soda.
CH - Now: 30 Target: 260 - Results: Add 698 oz. by weight or 558 oz. by volume calcium chloride. (That seems like a lot! Is this correct?)
CYA - Now: 0 Target: 40 - Results: Add 109 oz. by weight or 114 oz. by volume stabilizer. (Mine says it's 4 lbs., so that's 64 oz. by weight, right? I need another one, right? But not all of it? Can we swim in it while this is dissolving?)
Do these results seem reasonable? I'm afraid I'll screw this part up.
I'm concerned about the message under "Suggested FC Levels" that reads: "Note: Be careful if your CYA is really and truly zero!" I'm assuming mine IS really and truly zero since I couldn't get a reading on that test twice?
Also: "Unless you are shocking your pool, it is always best to add less than the full amount, wait a little while to allow the addition to mix thoroughly, and then retest to see where you are." So, add part of the suggested amount (half?), then test again in a few hours?
So, as per crabboy's post, I would add
part of the muriatic acid first, wait, test again. Add more if necessary, until the pH reading is good.
Then, I should add
part of the stabilizer, wait, test again, add more if necessary.
Finally, I should add
part of the chlorine, wait, test again, add more if necessary.
At what point should I add the baking soda? And can I wait a few days on the calcium chloride?
BTW, we got the vast majority of the debris out with the vacuum. Looking better! We might be able to net the little bit that's left out, or at least direct it into the skimmer.
Sorry to be asking so many questions! I feel clueless, and don't want to mess this part up. I am also totally exhausted, so if I don't make sense (or sound panicked, or grumpy
), please excuse me (I worked all night cleaning, etc. for tomorrow's party -- I've spent so much time working on the pool that my house was a mess -- NOT good for a party!).
