- Jun 24, 2021
- 16,091
- Vinyl
- CircuPool RJ-60 Plus
Post up another full set of results, we'll get you going. Also, test your fill water and post those numbers too.I'll watch it and start testing once I see FC fall under 10. Can you direct to me to the next channel where I can learn about the proper sequence to balance the water?
You can also share your logs with pool math, it will help us. Login to pool math with your ID/PW from forum. Go to home page. Press gear in upper right. Scroll to the bottom. Enable sharing with TFP.
Proper sequence is likely to get your pH balanced first, then your CH. If your pH starts with a 7, DO NOTHING. It will rise over time, when it gets to 8, reduce it back to about 7.4. Don't sweat a pH that starts with 7.
CH will be next, check out What Are My Ideal Pool Levels?
You will likely have to do nothing with TA, just manage pH and your TA will take care of itself. You will want to watch/test CYA about every 2-4 weeks.
