Folks....
Cleaning pool with Dolphin for the first time since opening. The 2ater temp is cold only 62 F. Dolphin is still functioning and doing what it is supposed to do but when it surfaces to tackle the waterline, it is squeaking. The squeaking noise appears to be in sync with the front wheel scrubber. I haven't used the cleaner before in water this cold so not sure if that is causing the noise or if it is something more serious. I had cleaned the impeller before putting it away for the season last fall. Any ideas on what this could be? Suspect it might be grit in the wheel housing. There was some post-winter grit/silt in the pool after the winter cover was removed. Cleaned as much as possible before releasing the robot
