Ok, first here's the current pool numbers:
I did a full drain/refill about 18 mos ago, and when I compare these results to my test data from the prior drain/refill, the CH rise is running about a year ahead of schedule. I hate to do another drain/refill before around the 3-year point, but at this rate if I wait until then I'll probably have a CH in the low four figures.
The only explanation I can come up with is that my fill water CH appears to be higher now than in years past. It was 175 for the longest time, but I just tested it yesterday from two bibs and now shows 250. A cost-cutting move from my water company, perhaps?
Any other thoughts would be appreciated!
