- Jul 21, 2013
- 53,526
- Plaster
- Pentair Intellichlor IC-60
I should probably retest with my outside spigot water since it is not softened.
test the water you add to your pool.
That would be nice, but would require some serious plumbing/construction work I think.Of course, test the water from which you will be filling the pool. Since you already have a whole house softener, I would connect that or another spigot to the softened water and your CH issues will be done.
I think you may not understand the consequences of VERY high CH like you will soon have if you continue to fill from a 350 CH source. CH doesn't go away.....it only accumulates in your pool and your CH will be over 1000 probably in your next swim season. Nothing is good about that and you will be forced to drain over half your pool.That would be nice, but would require some serious plumbing/construction work I think.
Thanks for the additional information. I need to get a better test on my fill water to see what I'm dealing with.I think you may not understand the consequences of VERY high CH like you will soon have if you continue to fill from a 350 CH source. CH doesn't go away.....it only accumulates in your pool and your CH will be over 1000 probably in your next swim season. Nothing is good about that and you will be forced to drain over half your pool.
Not trying to be part of the "don't run with scissors" crowd but I am trying to apprise you of a pretty serious upcoming calcium problem if you don't change something.
