After slam for mustard algae did final brushing, vacuumed and changed filter. While cleaning filter found large amount of what I assume is dead algae imbedded betweem the filter pleats. Should I throw the filter away or clean and reuse?
Can you suggest a method for soaking the cartridge in a bleach solution? I don't have any vessel large enough to submerge the whole cartridge. Green algae has been returning for us periodically all summer.
I have 2 cartridges that I alternate and both are in their second season of use. They never look completely "clean" after washing and scrubbing.
Our FC dropped to almost nothing (.5) while we were away for a few days. So I am getting the supplies to SLAM starting today.
I was swapping out 2 cartridges when fighting yellow algae. Since it was before I followed TFP and SLAMMing it went on for a long time (over a month) The filter gets gummed up just like it would during regular use, and you can clean it with a hose just like normal. As long as the pressure is ok after putting it back you should be fine. If not then you can soak the filter (as stated above). If soaking the filter still doesn't get the pressure right then it's time to replace (look for replacements on amazon not the pool store) But it sounds like you would be fine if you just clean it.
