So I made an impulse buy of one of the above ground vinyl pools with absolutely no previous knowledge or experience. I am pretty sure from reading the forums and researching the internet I have mustard algae. The pool was testing well (according to strip tests, I have ordered the in depth test reccomnded by the community) and then we went on vacation... and came home to what looked like sand in the bottom of the pool. Since we don't have an abundance of sand in the yard I thought it could be the metals from the well water we used to fill the pool as before we left I added hth metal scale powder.
So I have been cleaning the pool every day, spent endless hours and money buying different types of vacuums for fine sediment removal and when those didn't work I tried creating my own filter to add to the vacuum. I tried everything I could find on the internet yet everytime I would vacuum I could see the "dust" billowing out of the vents on the vacuum. So I decided to run the filter 24 hrs a day for a couple of days and readied the initial dose of pool clarifier. The water remains cloudy and everyday when I change the filter out there is this yellowish slime covering it. I want to slam but I'm such a novice I don't know what all the chemicals listed really are.
Can anyone link or post a list of what chemicals I should buy? I know ph up and ph down chlorine stabilizer shock and alkalinity up. I currently use chlorine tablets in a floater. I guess if someone could help me out with a shopping list I could use to order exactly what I will need to properly slam when the test kit finally arrives? I have attached pictures unfortunately I have just stopped running the pump so I can show a picture of the sediment when it has time to settle. If have inly seen this sediment on the floor of the pool not the walls and it doesn't stick to the pool brush like some guy in a video on youtube Said it should if it's algae.
