Long time BBB / TFP reader and believer. I am in central florida (Vero Beach)...12,000g pool, SWG
I think I have mustard algae. I keep my SWG pool FC between 5-10, but recent mega rain and deck runoff likely pushed up phos levels in my pool + I have been lazy this winter and did not brush the sides of the pool in a long time (...a year). I have automatic pool cleaner, so bottom of pool and bottom of the walls look fine. I went in the pool last week and noticed a haze over the side of the walls. Water was clear, but I saw a puff of "powder" come off the wall with brushing. From a distance, you can see a green/yellow patchy discoloration over parts of the walls.
I started the SLAM 5 days ago. FC levels 45-50 with pump running 24/7 for about 5 days now. I have been brushing with pole brush every day, cleaned filter every 2 days or so, and used Lanthium (PhosFree) to get phos down to 0 (....was 300-600).
However, minimal change in color on walls. I went into pool this AM, and pulled out the lights and cleaned the niches....there was "powder" in there...I suspect algae was camped out there as well.
I have to use a hand brush and scrub, scrub, scrub and then yellow color does come off the wall.
Questions-
-It will take me a few days to hand scrub the pool walls....do I keep the SLAM going the whole time with pump running 24/7...with FC 45- 50? (....my CYA is about 70)
-As much as I scrub, can I really get all of it off?
-As soon as the FC drops to normal levels, will it all just come back?
-is pH test and CYA test (TFT kit) still accurate with FC40+ range
-Any risk using the pool with FC 40-50 level?
Any input appreciated! Thanks.
Questions-
