Fiberglass pool with
FC 16.5
CC <0.5
CYA 40
Ph 7.6 CC
Chlorine level seems to be holding yet there is light brown greenish algae on the bottom of the pool in corners etc. There is also the white/gray "dust" that I assume is dead algae. No algae is growing on the walls (which I had last time I had an algae problem). The water is crystal clear.
Is it likely that what I am seeing is just dead algae?
New first time pool owner.
I have learned a ton from this forum. Thanks!
FC 16.5
CC <0.5
CYA 40
Ph 7.6 CC
