Muriatic acid
amin36
In The Industry
Nov 24, 2017
58
shahsavar
Guys
I am trying to find muriatic acid to lower the pool water PH.l know that muriatic acid is the same thing like hydrochloric acid but with less concentration having some impurities.the companies I contacted in my country produce hydrochloric acid with concentration between 30%-37%. Referencing pool calculator , I am finding different percantages.for example a company I contactacted only produces 30-32% but the numbers in pool calculator are diffrenet and the only near number in the pool calculator is 29.can I use this hydrochloric acid and choose the number 29 ?
And what is the difference between 31.45% and 31.45% - 20deg Baume hydrochloric acid?
And what do you think about using soda ash instead ?
Thank you so much
jimbethesda
259
Austin, TX
Soda ash raises the PH. % is just a number...adjust accordingly. You’re over-thinking it. 30-32% is a little higher than 29, so use a little less, then retest.
beautifulpool
115
North TX
Guys
Thank you so much
Amin36, Im not a moderator, but I do know this,
Soda Ash isn’t what folks use if they are trying to lower their pH.
You mentioned muriatic acid. the strength isn’t exactly the same as i see on my jug, its very close....i can vouch the hydrochloric acid does work Successfully in lowering pH.
Muriatic acid pH ⤵
Soda Ash pH ⤴
Ps don’t get down wind while pouring Acid
