- Jun 11, 2022
- 23
- Plaster
- CircuPool Universal40
I'm considering a stenner pump or DIY to automate muriatic acid injection. This is the final step to mostly put things on auto pilot.
However, I'm concerned about potential corrosion given my pool equipment is in a mostly closed room. As it is, I have white stains starting to show on the concrete walls (not sure what that is exactly) within a year of building. The door is made of fence picket, allowing for some ventilation. I would either punch a hole through the top of a jug of acid (with mild ventilation) or fill a larger container (stenner approach) and cover it.
1. Do you think putting (slightly) open muriatic acid in this room a valid concern or am I over thinking this?
2. Any thoughts on ventilating this out safely?
