Towards the end of last season I replaced my filter grids. Things were good.
Fast forward to now. I open the pool and am having sediment / de issues at the bottom of the pool.
-Vacuum the pool and sediment will started to accumulate on the floor
-Installed socks over the returns and I no longer get sediment accumulation
-Remove socks and put the multiport on recirc mode and I get de and sediment on the bottom of the pool. Recirc should be bypassing the filter.
The fact that this is happening on recirc mode leads me to believe I have a problem with the multi port valve.
Is this a simple gasket swap? Does the entire valve need to be replaced?
Multiport PN: SP0710XR50
