I have owned a pool for around half a year now and firstly had to deal with a leak in my sheer descent that led me to digging up and removing the entire thing. This lead me to learning a lot more about how pools operate to save me time and money in the future. After running the filter correctly and getting the pool looking perfect, it then went downhill and further issues came to pasture.
1 - the manual air bleed on my filter seems to now let air out when fully tightened. It leaks air and then will start to drip very slowly with water. Assume this is an air leak and I need to repair this valve?
2 - pool will backwash correctly and water will go through filter and out. However after backwashing and put into rinse and then filter the pool does not prime and emits a loud noise constantly. It never used to do this and would prime, not I can’t get it there. Is this a pump issue, skimmer issue, line issue - I don’t know what to trouble shoot. Water level is good at middle of skimmer and not leaking.
3 - before the filter started doing this I had an issue where I would have pump on filter and would lose pressure in jets within 10 mins, especially on the future from equipment jets on far side of the pool. Why is this? Is my pump not strong enough or is there other potential issues with the filter?
4 - the filter. After a while when the pool was clear (it’s now green as I can’t filter and have had a few storms) I would see the DE I put in the skimmer OR the dirt from the filter come back out and into the pool. Just looked like silt coming back in and I believe this is why when I shocked the pool didn’t turn completely clear. What does this mean with my filter? I backwashed, out in DE and repeated numerous time to clean but same issues with dirt and jet pressure. One common issue I saw was that it could be a crack in the top manifold? Thought and anything I can do to diagnose here?
Thanks for any help with above and happy to answer any questions or do any diagnosis / fixes myself. After buying this house and spending thousands on a leak I didn’t know about, I would like to save as much money and actually enjoy my pool rather than just spend money on it!
