I replaced the spider gasket on my Pentair multi-port valve. I purchased replacement gaskets on Amazon that were cross-referenced for my part number. I installed the gasket and used plenty of silicone grease on the gasket and in the channel of the multi-port. I re-installed the multi-port valve handle, everything sealed tight and no leak detected. Pump ran for several days with no leak. I vacuumed the pool and ran a backflush cycle. Once in filter mode, a small drip/leak was noticed from the backflush pipe. I repeated the entire process - lifted the gasket, applied more silicone grease, re-installed valve, ensured no leak. Back-flushed again to test the gasket and a small leak reappeared. A couple of questions:
Thanks for any advice offered.
- Has anyone had problems with after-market gaskets? Do I need to just find Pentair gaskets and use those?
- Is silicone grease the right approach to getting a good seal?
- I've read where some people use Loc-tite. Is that an option and why or why not use that? If you use Loc-tite do you only use it in the corners or the entire gasket surface area that contacts the channel?
- Any chance this is related to the valve instead of the gasket? I'm focused on the gasket because the leak stops whenever I manipulate the gasket.
