- May 3, 2014
- 62,912
- Fiberglass
- Pentair Intellichlor IC-40
Add 5 ppm FC worth of liquid chlorine into the pool each day with pump running until you get your kit.
You added about 24 FC to the pool. That's way too much to be dumping in blindly.Here are my recent results
FC .8
PH 6.4
TA 40
CH 59
CYA 0
I added 2.5 gallons of 10.5% LC about three hours before this test and it’s all consumed?
I can smell the chlorine if that’s what you’re referring to.Does the pool stink after you add the chlorine?
I don’t have any CYA in the pool yet, it’s brand new water. Guess I’ll just keep dosing with 5 ppm worth each day and leave the filter going 24/7 until I can get my test kit. Looks like it’s going to be next week due to the delay in shipping from the virus.You added about 24 FC to the pool. That's way too much to be dumping in blindly.
Some things to consider:
1) If there's a lot of algae or organics, it will consume all that bleach in a couple hours no problem.
2) If you had the soil bacteria that turns CYA into ammonia get into your pool, it would use it about as fast as you can pour. No CC test, so no way to know if that happened
3) If you have no CYA, it would all be gone due to sunlight in a couple hours.
So there's nothing to worry about yet, other than that you're blindly throwing chemicals into the pool and you're trusting someone else's test.
Yes, fresh fill from my deep well.You smell the CC - not the chlorine.
As Richard said above, don't blindly add chemicals with out testing.
I forget, was this a fresh fill?
OK -- not ammonia as you have not added any CYA. Algae grows fast in Florida.Yes, fresh fill from my deep well.
Thanks, FWIW, the poly-fill I added to the skimmer hasn’t changed much, so hopefully I’m just dealing with an algae outbreak. The water in the pool was without any chlorine for several days while it was being built.OK -- not ammonia as you have not added any CYA. Algae grows fast in Florida.
Yes, add enough DE to get a 1 point rise in pressure and reapply after each backwash. Your water looks great! Keep vacuuming to waste daily until all the dirt is gone.
