I started noticing a week or two ago that my polaris 280 was running very slow. I finally got some time to check it out and have a bit of a puzzle. I have a pentair pump going into a pentair filter (cartridge) which then hits a backflow preventer valve on to a flow measurement in line gauge, into a pentair heater, and to the return line back to pool. This is showing a flow rate of about half what it would normally show. PSI at the tank is 30 psi. I figured something might be blocked as we recently had heavy rains so I cleaned out the basket sweep and the basket in the pump.
After I turned on the pump again, it seemed to prime on its own but it took longer than normal and I had to put it on a higher speed (I just went from 2800 to 3400 or so RPM. It is clear that there is a flow issue "somewhere" - return valves are open, etc... But not sure how to figure out "where". Could the intake line from the sweep be plugged somehow?
