Hi all, first time posting but have been using the forums ever since purchasing a house with an old Sylvan pool a few years ago. Finally doing a face lift on the pool and have run into an issue with the pool light that I'm hoping to get some help with.
Situation: concrete decking has been demo'd and is waiting to be re-poured. New tile and coping was also installed and the pool is currently empty. I am taking this opportunity to update the old (non-functional) pool light as well as move the J box as it currently sits in the middle of the decking underneath where the diving board used to be. I purchased a 120v amerlite which I was able to retrofit to the existing stainless steel niche and am now working on extending/moving the J box to a more convenient location.
The Problem: Currently, the rigid metal conduit running from the nich to J box is acting as the means of bonding the niche, which I understand is acceptable. In order to maintain this form of bonding, my understanding is that I will need to extend the conduit with brass conduit. Brass conduit doesn't seem to be carried by normal hardware stores and from what I've seen on line can be quite expensive.
I have seen that another option is to extend the conduit using PVC conduit, but would then need to run bonding wire back to the niche. This would be fine, but my old niche doesn't seem to have a bonding lug that is included on modern light niches.
Questions:
1. Is there any recommendations on where to locate brass conduit and corresponding fittings? I am located in Southeastern PA.
2. Is there a safe/acceptable way to bond an existing wet niche that doesn't already have a bonding lug?
3. Would it be more economical to ditch the 120v light I purchased and go with 12v fixture, transformer, and PVC conduit if bonding cannot be easily achieved?
Thanks in advance for any help/recommendations!
Questions:
