- Nov 12, 2017
- 12,647
- Plaster
- Pentair Intellichlor IC-40
Rain? Oh yah, I remember rain. Drops of water falling from the sky, right?
Looking at you pool build, I'm wondering how things are working out with the 250Kbtu heater and solar pre-heat. How much was the solar install, BTW?Rain? Oh yah, I remember rain. Drops of water falling from the sky, right?![]()
I didn't build my pool, I inherited it from the previous homeowners. I've never once turned on my gas heater, so can't offer any thoughts about it. I installed my solar heater myself, but that is my primary heater, not used as a pre-heater. I'm not even sure if it could be used as one, as I've never tried to run both heaters at the same time. Can an EasyTouch do that? (Not sure.) You might confirm how that works on an IntelliCenter before you make your plan.Looking at you pool build, I'm wondering how things are working out with the 250Kbtu heater and solar pre-heat. How much was the solar install, BTW?
I considered a smaller heater but just went with the 400kBTU instead. I'm also considering adding solar pre-heat in the future.
My solar only requires one actuator, as there is only one valve that manages the flow through the solar panels. On an EasyTouch, that actuator has a dedicated connection on the motherboard, no relay needed for solar control. Same goes for the gas heater. There is no actuator or relay needed for the gas heater. And neither uses up any of the feature programming slots in the software, which offers control of the two heaters separate from running lights or water features. I'm gunna go out on a limb and say the IntelliCenter offers at least all that.I believe all that is needed is two Valve Actuators and another relay
Any thoughts or suggestions would be greatly appreciated!Back to railing. I need to order concrete inserts. Is SS necessary or will brass suffice?
Or is plastic even good enough?
So what do you use for a "Sun Comes Up" Sensor? A timer or can it be set to change with the time of sunrise or sunset each day? With my home automation system I can assign triggers based on x minutes before/after sunrise/sunset. If the need arises to cool my pool at night I would like to even set a trigger based on pool water temperature and time of day.Typically, gas heaters are plumbed so that water flows through them all the time, any time the filter pump is running. You don't shut off flow through them. You just turn on the gas when you want it to heat the water. So unless you have a need for a bypass, there are no valves involved.
Solar heaters have an actuated valve to control flow through them so that you don't have to pump water through them when you don't want to heat the water. And so you're not pumping water through them when they can't actually heat the water. Their restriction would be pretty hard on the electric bill otherwise. And you don't want water running through them when a cloud passes overhead. Gas heaters don't have those considerations.
There is some restriction through a gas heater, too, but I think they are not normally bypassed because I think they're not supposed to be left to dry out. Not sure on that, but others here will know.
Study these animations to get an idea of how solar is normally plumbed. This site taught me most of what I needed to know for my install. You'll see some red-handled PVC ball valves in the drawings. Those are optional. Study what the solar valve is doing. There is both a tee and a valve on the return ("exit") side, but it only needs to be a check valve. It does its thing without any intervention necessary, manual or automated.
Plumbing a Solar Pool Heater | Hot Sun Solar Pool Heating
The basic concepts you must know to correctly plumb a solar pool heater.www.h2otsun.com
Wander around that site, there are a few pages that lay out the principles of the plumbing and the panel installation.
My pool's automation controller (EasyTouch) compares the pool's water temperature to the available heat on the panels. Two dedicated temperature sensors are used for that. And the EasyTouch can schedule when the solar heater runs. So: when the pump is on, and the time of day is within the set solar heating schedule and the heat on the panels is such that they could raise the pool's water temperature, the EasyTouch operates the solar valve's actuator. Water flows through the panels and clears out all the air that they might contain, and heating commences.So what do you use for a "Sun Comes Up" Sensor? A timer or can it be set to change with the time of sunrise or sunset each day? With my home automation system I can assign triggers based on x minutes before/after sunrise/sunset. If the need arises to cool my pool at night I would like to even set a trigger based on pool water temperature and time of day.
Painting PVC can be problematic in the best of conditions, add to that the harsh environment of a roof top, hot and cold and UV, and then the constant temperature swings, and painted PVC is eventually going to peel and look bad. There are three solutions that I know of:Also builder told us afterwards that we needed to get the solar pipes painted and that if we’d had the paint ready the day of install the installers would’ve painted the pipes, so it’s something to ask about when getting quotes.
Still looking for input on rails. Concrete pour is less than two weeks if all goes according to plan.Any thoughts or suggestions would be greatly appreciated!
I had galvanized and they were going strong 9 years later when we moved. Brass would fare even better.Still looking for input on rails
BrassSo plastic, brass or stainless inserts for a handrail?
Allen, what about the galvanic corrosion properties involved? Should the insert be the same material as the rail? Or does brass cover that issue?Brass
Brass is frequently used as the buffer between 2 dissimilar metals because it's iron content is so low, it will not rust.what about the galvanic corrosion properties involved? Should the insert be the same material as the rail? Or does brass cover that issue?
